NEED to replace pushrods when replacing rockers?
Old Sep 12, 2002 | 12:41 PM
MrNuke's Avatar
MrNuke
Default NEED to replace pushrods when replacing rockers?
If I put ne roller rockers on my engine, do I need to replace the pushrods? :eek: :eek:
Old Sep 12, 2002 | 12:52 PM
scorp508's Avatar
scorp508
Are you getting self aligning or non-self aligning rockers? If you get non's, I would most definitely get some heat treated pushrods and guideplates. About $50 total.
Old Sep 12, 2002 | 01:09 PM
vettmech's Avatar
vettmech
Default Re: (scorp508)
When you replace rockers it's always a goos idea to change the puchrods too....... they don't add much to the parts bill you already have and like Bob Vila says......."ya might as well"........ :yesnod: :seeya
Old Sep 12, 2002 | 01:26 PM
MrNuke's Avatar
MrNuke
Default Re: (vettmech)
Is it easy to install pushrods once you have the rocker off?
I never did any work on my heads, so this is a new experience to me..
I'll be replacing my rockers too this or next week look sliek so migh taswell do them at the same time..
Old Sep 12, 2002 | 01:28 PM
scorp508's Avatar
scorp508
You pull em out and drop new ones in. Just like putting crayons back in the box. :)
Old Sep 12, 2002 | 02:08 PM
MrNuke's Avatar
MrNuke
I shoudl be able to handle that.. :crazy:
Old Sep 12, 2002 | 02:15 PM
jefft84's Avatar
jefft84
Default Re: (MrNuke)
You can see the lifter through the head where the push rod has to go. When you do reinstall be sure to put some assembly lube on both ends of the rod to help lube on startup. The stuff is only about 4 bucks at most parts stores. Or just grab some Vasaline and use it. {Go Ahead and flame me for that one guys} :)
Old Sep 12, 2002 | 03:19 PM
Irocan's Avatar
Irocan
Great analogy! Scorp you kill me.
Bob
[Modified by Irocan, 7:19 PM 9/12/2002]
Old Sep 12, 2002 | 03:29 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: (Irocan)
But Scorp, I could never get all of them to fit back into that box right, especially the 64 crayon box. This is complicated stuff! :lol:
Old Sep 12, 2002 | 03:36 PM
scorp508's Avatar
scorp508
Hmm.... then do what I did. Smash them into place and if you scrape a few lables off, so be it.
Old Sep 12, 2002 | 03:40 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: (92TripleBlack)
I can see it now the new 64 valve V-8, powered by Crayola.
[Modified by Nathan Plemons, 1:41 PM 9/12/2002]
To NEED to replace pushrods when replacing rockers?
