You are going to need to get someone to rewrite the code to make it not see the fault.
I have equipment and some knowledge. I just need to know what and how much to change. I think, but not sure all I have to do is increase the temp number to max in the section that says "disable egr if x< 54 degrees. I am using $6E. Or $E6, which ever it is. Would like to hear from somebody who knows for sure
You mentioned that you feel you've got the equipment. Mention the equipment you have/want to use in this thread OR start a NEW THREAD ASKING FOR HELP with XXXXX PROGRAMMING 1227165 ECU.
are you reprogramming the stock chip? are stock chips even reprogrammable?
I am using Moates adapter On 89 you can't flash stock chip. You have to use piggy back Go to Moates site. They have good information. I used a burn 2 to write to chip using tunerpro rt as editing software
