89 vert-runners and plenum torque ##'s??
Old Sep 12, 2002 | 06:55 PM
6spd89's Avatar
6spd89
Cruise-In II Veteran
Default 89 vert-runners and plenum torque ##'s??
Do you know what they are for my 89??
Runners at the intake is ????? ft./lbs
Plenum torque is ????? ft./lbs.
Thankyou,
Matt
Oh also would you prime the rail and check for leaks before reassembly??
Just in case the injectors or the new rail o-rings leak.
Don't need gas squirting at 40psi with the engine running!!!
Matt
Old Sep 12, 2002 | 07:15 PM
1MoorTym's Avatar
1MoorTym
Default Re: 89 vert-runners and plenum torque ##'s?? (6spd.89)
runners to manifold - 18lbs.
runners to plenum - 18lbs.
Probably not a bad idea to pressure test, would not know to do it though.
I didn't test mine, luckily it didn' leak.
Old Sep 12, 2002 | 10:00 PM
6spd89's Avatar
6spd89
Default Re: 89 vert-runners and plenum torque ##'s?? (1MoorTym)
Thanks 1moor tym!!! I knew it wasn't much as easy as they came off.
Gotta go rebuild my fuel rail first,new o -rings!!injectors,blah,blah..
Thanks,
Matt
To 89 vert-runners and plenum torque ##'s??
