dana36 or dana44?
Old Sep 13, 2002 | 02:45 AM
sinistervette's Avatar
sinistervette
Default dana36 or dana44?
85 vette, 4+3, rpo #G44. Is this a dana 36 or 44? It should be 3.07 ratio? If it is dana 36, will a dana 44 fit right in? What years had dana 44? Did any come with 3.73 gear? Is there a visual difference between the 36 & 44? TIA! :cheers:
Old Sep 13, 2002 | 04:39 AM
IT L GO's Avatar
IT L GO
Default Re: dana36 or dana44? (sinistervette)
All standard shift C4's had Dana 44's
All Auto's had Dana 36's
All 4+3's had 3.07 with some of the early 84's had 3.31(?)
All 6 speeds had 3.45's except some of the early 89's had 3.54
Dana 44's have two bolts across the top and 36's have 3
Hope this helps
:chevy
Old Sep 13, 2002 | 09:01 AM
Corvette0096's Avatar
Corvette0096
Default Re: dana36 or dana44? (IT L GO)
Hope this helps
:chevy
84's had a 36 one way or the other. :cheers:
Old Sep 13, 2002 | 09:08 AM
vader86's Avatar
vader86
you have a D44
Old Sep 13, 2002 | 03:35 PM
JoBy's Avatar
JoBy
Yes, you should have a Dana44.
This is a Dana 44 and a Dana 36 (44 on top)
Old Sep 13, 2002 | 06:46 PM
sinistervette
Default Re: dana36 or dana44? (JoBy)
Once again, THANKS A TON! This place is great. I apreciate all your help, and the pictures of both rears was killer! :cheers: Thanks guys.
To dana36 or dana44?
