Exhaust Upgrades
Old Aug 28, 2016 | 04:43 PM
Poppa Dukes's Avatar
Poppa Dukes
Cruising
Default Exhaust Upgrades
I installed muffler delete pipes on my 94, it sounds OK but the drone sucks, so I want to install a MagnaFlow 12468 performance muffler with a tru-X core in place of the resinator which should get rid of the drone. My question is 2.5" or 3" pipes ? not sure which to order.
Old Aug 28, 2016 | 05:41 PM
ddahlgren's Avatar
ddahlgren
Closest to match existing system seems to make the most sense...
Old Aug 28, 2016 | 08:01 PM
TurbineSurgine's Avatar
TurbineSurgine
If I where you I would use the 2.5 but i don't think that muffler will get rid of drone, I have it with two individual glasspacks right behind it and still have drone. I would go with a chambered muffler to lose drone.
Old Aug 28, 2016 | 08:50 PM
TA's Avatar
TA
If you don't want drone..............either go back to stock or get a Corsa system
Old Aug 29, 2016 | 09:12 AM
9T3VETTE's Avatar
9T3VETTE
This is my experience as well. My magnaflow system drones quite a bit.
Old Aug 29, 2016 | 10:51 AM
ddahlgren's Avatar
ddahlgren
So does my Borla. It seems like you have to lower the windows to let the drone out LOL.
I did a check for stock at NAPA and went to Walker exhaust and no muffler listed either place for my '91.
Where would you buy one if you wanted one?
Old Aug 29, 2016 | 12:27 PM
DMITTZ's Avatar
DMITTZ
I just got new exhaust for my 88' because it had terrible drone due to having hooker muffler put on by the PO. I used dual 2.5 pipes my exhaust shop bent to fit with an X-pipe (from summit) and stock mufflers. It still has a nice rumble at idle and sounds good when you get on it, But is very quiet at highway cruising speeds. I'm very happy with the sound.
Just a note, I got the stock replacement mufflers (for a 91') from Corvette Central and my exhaust guy said he a little bit of trouble because the pipes that were attached to the muffler were not bent correctly, but after he re-bent the piping a bit it all worked out.
Old Aug 29, 2016 | 03:11 PM
Poppa Dukes
Cruising
SO you are using that exact muffler with the Tru-X pipe built in and you still have drone ? Well that sucks I guess I will be trying something else then.
Old Aug 29, 2016 | 08:13 PM
ddahlgren's Avatar
ddahlgren
DMITTZ where and what brand mufflers?
Old Aug 29, 2016 | 08:19 PM
DMITTZ's Avatar
DMITTZ
The mufflers were sold by Corvette Central and were stock replacement ones for a 1991 Corvette (dual outlets). they were $198 I think, and the X-pipe from summit racing was $34.
They sound great with dual 2.5in and an x-pipe.
Just be aware as I said earlier that the pipes that come attached to the mufflers will have to be massaged a little bit in order to work as they are not bent correctly.
Old Aug 31, 2016 | 01:47 PM
hawk454's Avatar
hawk454
Flowmaster 50 series drone as well for me around 1300 RPM.
To Exhaust Upgrades
