Scanners
Old Sep 10, 2016 | 07:48 PM
-=Jeff=-'s Avatar
-=Jeff=-
No it is an ADX scan file for 92-93
the EE file you have is for 94
Old Sep 13, 2016 | 02:37 AM
confab's Avatar
confab
I have a couple of Mac Mentor tools, and I like them a lot. Much more than the MT2500.
They're a glorified OTC Genesys type scanner and work well for OBD1 vehicles.
Old Sep 17, 2016 | 04:57 PM
BLUDICE's Avatar
BLUDICE
I went to O Reilly to have my '94 scanned - to see if there were any codes it - just got the car last month - hooked it up and it couldn't "connect" - tried several times - they said I needed to see if the fuse is blown - went home to pull the manual and can't find it in the manual - help please.
Old Sep 17, 2016 | 04:59 PM
aklim's Avatar
aklim
You have to see what brand of scanner they are using and check with the company as to whether it can or cannot read your car.
Old Sep 17, 2016 | 06:17 PM
BLUDICE's Avatar
BLUDICE
I guess I was assuming they would do that before trying to hook it up - it was a blue unit that said it was for 1 & 2 types.
Old Sep 18, 2016 | 08:25 PM
dpc4vett's Avatar
dpc4vett
Ya. I have a code scanner. I bought a USB to ALDL connector for my computer. Am trying to figure out what is the easiest to use and doesn't cost an arm and a leg.
Old Sep 18, 2016 | 08:28 PM
aklim's Avatar
aklim
If it is a code reader, it should be cheap. I'd get a scanner that can read live data or forgot it and borrow from someone who has one.
Old Sep 18, 2016 | 08:32 PM
dpc4vett's Avatar
dpc4vett
To scan for trouble codes the scanner has to have a jumper from the ALDL A and B terminals. To read real time data you need to have a resister in the interface cable to I believe terminal. www.aldlcable.com
