A/c
Old Sep 3, 2016 | 07:19 PM
firsttimechevy's Avatar
firsttimechevy
Default A/c
have 1995 corvette and have not turned it on for about a month when I jump started the car I left it on for a while but I noticed that the a/c compressor was not kicking in I checked the fuses and they were all good I never had problems with it car is in great shape only 63 k origanal miles.
Old Sep 3, 2016 | 10:48 PM
desertmike1's Avatar
desertmike1
I would avoid doing this, it's best to disconnect the Battery and fully charge it. These car's are loaded with micro-processors and any time you jump start one, there can be Voltage/current transients all over the electrical system.
Try a battery disconnect and recharge, followed by a reconnect. re verify whether or not the A/C is working. (If not) try interrogating for stored codes in both the ECM, and A/C programmer. Codes 66-70 in the ECM will prevent the A/C clutch from engaging. As well as several codes in the A/C programmer.
If the Battery is fully charged and "No" codes are present then there can be other issues that will prevent the system from working such as a low charge.
Old Sep 3, 2016 | 10:49 PM
desertmike1
I forgot to add these;
http://tech.corvettecentral.com/2011...trouble-codes/
To A/c
