help 1989 corvett
Old Sep 5, 2016 | 11:08 AM
gt2720's Avatar
gt2720
7th Gear
Default help 1989 corvett
need wiring diagram for under dash have no power to heater control or heater fan fuse is good but has no power at it what wire supply the power and from where
Old Sep 5, 2016 | 05:46 PM
mr.beachcomber's Avatar
mr.beachcomber
I'll be glad to help you out with the wiring diagrams, but first, I need to know if your '89 has the electronic control unit for the HVAC system, or if it has the manual control system that requires movement of levers. Two completely different wiring schematics.
Old Sep 5, 2016 | 05:49 PM
mr.beachcomber
If you're not sure which system you have, consult the option codes on the inside of the glove box cover. Option C68 is the electronic control, and C60 is the manual control. Hope this helps.
Old Sep 5, 2016 | 06:05 PM
gt2720's Avatar
gt2720
7th Gear
Default 1989 power problems
I have the c68
Old Sep 5, 2016 | 06:29 PM
mr.beachcomber
Roger. I've attached a PDF file with the wiring schematics and trouble-shooting steps from the FSM. Let me know if you need additional info/schematics. (Sorry about the blurry images at the binding. The FSM is really almost too thick to scan properly.)
File Type: pdf
Old Sep 5, 2016 | 06:34 PM
antfarmer2's Avatar
antfarmer2
Check your fuses. And fuseable links.
Bet yours is the same as the other guys. LMAO
To help 1989 corvett
