Hard starting 87
Old Sep 7, 2016 | 06:17 PM
calracer's Avatar
calracer
Default Hard starting 87
Hard to start but when I keep it floored it will finally start .Takes a few moments to idle properly.I can hear the fuel pump for a few seconds as I turn the key.I put a fuel pressure gauge on and see 39-42 lbs when I turn on.
It will stay in that area while it runs .When I turn it off I notice that with in 2 minutes it will go down to zero. I check the oms on 2 injectors and read 15.9. I notice a tiny bit fuel in front of the distb. on the rear of the manifold .
Is it flooding some how?
Old Sep 7, 2016 | 06:26 PM
antfarmer2's Avatar
antfarmer2
Pull the vacumm line off the FPR and look for fuel. And smell your oil.
Old Sep 7, 2016 | 07:46 PM
calracer's Avatar
calracer
Default pulles vacumm like
I pulled the vacuum line of and gas came out ?
Bad FPR or what is it?
calracer's Avatar
calracer
Default pulles vacumm line
Old Sep 7, 2016 | 07:47 PM
calracer's Avatar
calracer
Default pulled vacumm line
I pulled the vacuum line off and gas came out ?
Old Sep 7, 2016 | 07:48 PM
PatternDayTrader's Avatar
PatternDayTrader
Yes - Do your very best to run the car as little as possible until you replace the regulator and change the oil. In fact I wouldn't even start it again if it were me.
Old Sep 7, 2016 | 07:50 PM
antfarmer2's Avatar
antfarmer2
Originally Posted by Amotoxracer
Yes
Yes.....yes and yes. might want to check your oil for fuel and change it do not want a grenade.
Old Sep 7, 2016 | 08:04 PM
calracer's Avatar
calracer
Default gas in FPR
Ok wow, so I got a bad FPR. Thanks. I 'm glad I know now.Before I start it again I will put a new FPR and change the oil and filter. It has always started right up until recently . I'll take care of it asap.
To Hard starting 87
