installed GM LT4 roller rocker kit
Old Sep 13, 2002 | 09:19 PM
c3girl's Avatar
c3girl
Default installed GM LT4 roller rocker kit
I have the valve lash set but the valve covers won't go on. I think the tabs in the valve covers aren't clearing the new rockers. Should I try to remove the tabs from the valve covers or do I need LT4 rocker covers?
Old Sep 13, 2002 | 09:25 PM
93Blackrose's Avatar
93Blackrose
Default Re: installed GM LT4 roller rocker kit (c3girl)
Remove the tabs on the covers you have.
Old Sep 13, 2002 | 09:26 PM
c3girl's Avatar
c3girl
Default Re: installed GM LT4 roller rocker kit (93Blackrose)
gotcha.
what did you use to remove them?
I don't want to damage my covers.
Old Sep 14, 2002 | 04:20 AM
khornet's Avatar
khornet
From: Phx/but its a dry blast furnace kinda heat AZ
Dremel Tool :yesnod:
Old Sep 14, 2002 | 09:26 AM
Nathan Plemons's Avatar
Nathan Plemons
You should be able to just grind down the drip tabs and you'll be fine. Using a dremel tool or a die grinder will do the trick. Just be sure and clean out all of the debries when finished. You don't want any of that crud floating around in your motor.
AND, you're not gonna get away that easy! You've got to tell us a little bit about yourself and your car. I looked up your posts and I see a few questions but no info from you. Tell us about yourself and your car, post some pictures and such. The more we know about your car the more we can help for any given question.
Old Sep 14, 2002 | 11:23 AM
BBA's Avatar
BBA
Default Re: installed GM LT4 roller rocker kit (Nathan Plemons)
Dang c3girl...your stirring up quite a bit of interest here in a short time, lol :chevy
To installed GM LT4 roller rocker kit
