Help with problem?????
Old Sep 13, 2002 | 09:49 PM
cgc2001's Avatar
cgc2001
Default Help with problem?????
Hello, I have a 1994 corvette I replaced the cap and rotor and plugs and wires on my vette, know when i start it up the idel wont set, anyone else have this problem and know of a fix... Thank you :cheers:
Old Sep 13, 2002 | 10:18 PM
ittlfly's Avatar
ittlfly
Default Re: Help with problem????? (cgc2001)
I994?? Cap???rotor??? Opti???? The 94 (as far as I know) uses an opti spark. What exactly did you repalce? Did you replace the cap and internals on the opti?
Old Sep 14, 2002 | 01:05 AM
cgc2001's Avatar
cgc2001
Default Re: Help with problem????? (ittlfly)
Yes I replaced the cap and internals know the idel wont set seems like it has a surge high then normal high then normal...
Old Sep 14, 2002 | 11:07 AM
cgc2001's Avatar
cgc2001
anyone else had this problem??????? Thank you for any info you can give or know what it is....... :cheers:
Old Sep 16, 2002 | 11:28 PM
cgc2001's Avatar
cgc2001
Ran trouble codes today none foound. I double checked all my connections and they looked to be fine. I am stuck??? When you first start it, it seems fine for about 10 to 15 seconds then starts to rev in short quick intervals then is ok then starts up again. anyone know what this could be.... :cheers:
To Help with problem?????
