car cranks but will not start
Any help would be appreciated.
Rich
Sorry fuel pump relay.
Might want to look at the connections to the fuel pump since you were just there. And check your fuse.
There is a plastic latch and locking collar that holds the connector in place. You must unlatch it to remove the connector.
Some cars have a combination oil pressure sender and oil pressure switch in one unit. It looks like this:
Do you have the FSM for your car?
if you cannot read pressure or hear the fuel pump run - key "on" for two seconds, look into the fuel pump relay (assuming the FP fuse is good). if the relay is bad, or has a grounding issue, cranking the engine until oil pressure gets above 4PSI should by-pass the relay and allow the engine to start. chances of both a fuel pump/relay issue (or related), and a oil pressure switch issue at the same time are pretty slim.
start with a proper fuel pressure diagnostic test per the FSM. everything else here is second guessing. the basic "key on - 42 psi - 2 second" thing says a lot.
right now, and I'M second guessing, but it sounds like you have zero fuel pressure - now you have to figure out why. good luck - keep us informed.
edit: as for my filter comments, I need to ask - did you have this issue before or after you replaced the fuel filter? if after, most likely there is no issue - I was just looking down all avenues.
