rear gears
Old Sep 12, 2016 | 09:35 AM
steven mack's Avatar
steven mack
Default rear gears
Does anybody know how I figure out what gears I have In my 87 from the numbers on my console lid build sheet?Thanks Steve
Old Sep 12, 2016 | 09:44 AM
antfarmer2's Avatar
antfarmer2
Post a pic.
Old Sep 12, 2016 | 01:55 PM
Benny42's Avatar
Benny42
G92 is performance axle = 3.07
Is it a manual or automatic ?
Old Sep 12, 2016 | 02:23 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Some of the C4 ratios/RPO codes that I found.
G92 - Performance axle ratio
GM1 - 2.59 Rear axle ratio
GU2 - 2.73 Rear axle ratio
G44 - 3.07 Rear axle ratio
GW4 - 3.31 Rear axle ratio
GT7 - 3.33 Rear axle ratio
GM3 - 3.45 Rear axle ratio
GHO - 3.54 Rear axle ratio
Old Sep 12, 2016 | 04:30 PM
steven mack
Thanks For the info guys .QCVette I see I have the crummy 2.59 gear ratio.I have to shift out of overdrive into drive going up hill because I have 17" rims and taller tires.
Old Sep 13, 2016 | 10:10 AM
QCVette's Avatar
QCVette
.... I see I have the crummy 2.59 gear ratio.....
On the plus side it is great for highway mpg. On my '88 with a 2.59 I was getting 30 mpg on my highway commute.
Old Sep 13, 2016 | 02:01 PM
steven mack
You are right QCVette.And my instant mileage Tells me I am getting 80 miles to the gallon,but that's down hill.You are correct I do get good mileage.That is a plus.
Old Sep 13, 2016 | 08:05 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Even with the extra umpph...of your 400 ci motor?
Are you sure your tires/wheel combo is bigger around than "stock"? Are you running 275-40s?
Old Sep 13, 2016 | 09:37 PM
steven mack
I'm running 315-35-zr17.I don't have to shift out of overdrive .It's just more fun to be in my power band.There's a lot more in my motor I just have to get it tuned.I haven't tried tequilaboys tunes yet I am going to put the modified ECM in tomorrow.And thanks for the moates sight I had the memcal in wrong on the adapter.I didn't know the adapter would fit without taking the ECM case apart If I just removed the blue cover on the memcal.I can't believe Tequilaboy kept all my information on my chips he burned for me 5 years ago .He E:Mailed all the info to me last night.
Old Sep 14, 2016 | 08:54 AM
KSA Aaron's Avatar
KSA Aaron
Factory gear ratios for '87...
Coupe was 2.59D36 base with auto, performance 3.07D36.
Coupe was 3.08D44 base or performance with std trans.
Convertible was 2.73D36 base with auto, performance was 3.07D36.
Convertible was 3.08D44 base or performance with std trans.
Old Sep 14, 2016 | 09:36 AM
steven mack
KSA Aaron,thanks for the info,Steve
Old Sep 14, 2016 | 03:05 PM
Dt86's Avatar
Dt86
I used to have a 2.59 rear. On top of gas mileage I did like the sound of the motor running through the gears. Kind of miss that. But 3.07 is so much better!
To rear gears
