How to remove A.I.R.
Old Sep 14, 2002 | 10:29 AM
ZRWANABE's Avatar
ZRWANABE
Cruise-In III Veteran
Default How to remove A.I.R.
I broke a line while i was doing my headers and i just wanted to know if i really need A.I.R. or if i can take it off
If i can take it off exactly what do i need to do it
I really dont wana have to buy a line so if i can just take it out that would be great
but i dont wana hurt anything
Old Sep 14, 2002 | 11:39 AM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: How to remove A.I.R. (ZRWANABE)
The AIR system helps to keep your Cats from clogging. If you are still running cats, keep the AIR.. if not, you can ditch it, by just getting rid of all the plumbing, and plugging up the holes in the manifolds with bolts, and making a plate to go over the intake manifold connection.
-Mark
Old Sep 14, 2002 | 01:13 PM
nickd's Avatar
nickd
Default Re: How to remove A.I.R. (MarkLT1)
There are (2) 10mm bolts holding the AIR tube to the back of the intake manifold. You'll need a gasket & blockoff plate there.
There is a bolt on the back of the pass.side head holding the AIR tube bracket to the head I forget what size it is ( 14mm or 9/16") .
The bracket is slotted so all you need to do is get the bolt loose but it's tough to get at. The rest of it comes apart pretty easily.
Old Sep 16, 2002 | 01:44 AM
ZRWANABE's Avatar
ZRWANABE
Default Re: How to remove A.I.R. (nickd)
removing all the lines was easy cause i pulled the heads off the car
what i would like to know is how do i get rid of the A.I.R. pump
Old Sep 16, 2002 | 08:32 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
You could ship it to me, I need a new one, or at least one that works, and doesn't shake my serpentine belt and make excess noise.
Old Sep 16, 2002 | 10:10 AM
ZRWANABE's Avatar
ZRWANABE
Default Re: How to remove A.I.R. (CentralCoaster)
does anybody know if they make a kit for removing the pump or if i can put my belt on a differant way like i did on my camaro???
Old Sep 16, 2002 | 12:49 PM
VetteRacer282's Avatar
VetteRacer282
CentralCoaster: Need an AIR Pump? I will have mine up for grabs as soon as I figure out the new bracketry (know what to do, just gotta get it done and verify it'll work).
It'll go for a resonable price if your intersted, its all cleaned up too...
Email me and let me know
As for the posters issue, the LT1 used an electric AIR Pump I beleive, so all you should have to do is disconnect whatevers there and cap off at the exhaust (then send it to me so I can design a smog legal car again :p:) They make an eliminator bracket for the L98s...
Goodluck
Matt
Old Sep 18, 2002 | 09:36 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: How to remove A.I.R. (VetteRacer282)
Please let me know if you get rid of the AIR Pump......How will you pass the smog check......
Maybe your hints will help me get rid of mine, here in Huntington Beach, CA.
PLEASE LET ME KNOW......
thanks
tony
:smash: :smash: :nopity :nopity :nopity :nopity
Old Sep 19, 2002 | 05:07 PM
CentralCoaster
No thanks, it looks like it won't fit on pre-87 cars. I may be interested in Oldace84's though, that would fit. It sounds like mine has bad bearings.
Old Sep 19, 2002 | 05:19 PM
TIMSPEED's Avatar
TIMSPEED
ZRWANNABE,
LT1's have Electic A.I.R. pumps that are down in the nosewell. (behind the foglights) So I don't know what exactly you're trying to get rid of? :confused: Having smog stuff on LT1 doesn't really do any harm (performance wise)
Old Sep 20, 2002 | 01:28 AM
bigmikecfl's Avatar
bigmikecfl
Default Re: How to remove A.I.R. (TIMSPEED)
saving two pounds.. FOR THE HOLESHOT!..
sorry, bad movie reference.
Old Sep 20, 2002 | 10:10 AM
VetteRacer282
Default Re: How to remove A.I.R. (oldace84)
Oldace: For now, its paying for smog (~$100 extra). I have a few places I can get it done.
Check with your local speed shops, most will know a guy or two that can "pass" the car.
Eventually I want to put an electric pump in, just so I can somewhat go legal (would still have to swap exhuast out) if I ever needed (hopefully wont live in naziville... errr California :rolleyes: long enough to worry about it though :D
I got rid of it for looks, etc... the current setup is going to be idler pulley in stock area (custom bracket, but same general location), Powersteering pump in stock location/bracket, and alternator in stock area with stock/custom bracket (heim jointed inplace of AIR pump). At some point it will be waterpump and alternator, with a custom bracket and V-Belt setup... nothing quite like electric pumps (Water, PS, AIR)
Let me know in an email if you cant find a shop to Pass you. I may be able to check a few references and see what I can find..
Matt
To How to remove A.I.R.
