1985 EZ EFI install
My Questions are:
Can I mount this in-tank pump to the stock 85 sending unit?
Should I upgrade to 3/8 return line or will the stock 5/16 work?
Any tips on mounting location for the ECU
Is there a way to remove the Fuel injector harness without cutting it or removing the whole engine harness?
Do I NEED to use a MSD ignition box
If there is anything else I'm missing or if you have and tips from your install that would be greatly appreciated
Thanks Justin
