Polishing plenum
Old Sep 14, 2002 | 01:55 PM
dbwade36's Avatar
dbwade36
Default Polishing plenum
Well, I started polishing the plenum this morning. I am using rotary sander for large sections and dremmel (steel wire brush adaptor) for smaller areas. It is definately looking better, but what do I use to "finish" it off. You know, remove the small abbrations and swirls made by drill/dremmel.
Old Sep 14, 2002 | 02:10 PM
KYVette90's Avatar
KYVette90
Default Re: Polishing plenum (dbwade36)
Work up in increments until you finish by wetsanding with 2000 grit sandpaper. Then hit it with some aluminum polish.
