Wobbly Crank hub?
Old Sep 14, 2002 | 02:36 PM
sputnick's Avatar
sputnick
Default Wobbly Crank hub?
Was just outside looking at my engine and thinking about removing my iac for cleaning when i noticed that my crank shaft hub or balancer? was wobbly. Then engine was relatively immobile so i am fairly certain that the wobbling is isolated to the crank hub. is this normal? and what might cause it? bent crank?
Old Sep 14, 2002 | 02:50 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Wobbly Crank hub? (sputnick)
If the pulley and damper were wobbling tighten the four bolts; it it was just the damper, replace the damper as it has likely separated.
Old Sep 14, 2002 | 02:57 PM
Rich B.'s Avatar
Rich B.
...DANGER, Will Robinson, DANGER!!!... :crazy:
Advice above is the best I've heard...
To Wobbly Crank hub?
