1994 Airbag light headache
1994 project ran into a tree and both airbags deployed. Replaced both airbags, modulator SRS and arming sensor but airbag light will not go out. Am I missing something? Ready to take it to the dealership and spend big money. Looks like maybe low voltage at driver side airbag (less than 1 volt) but I am not sure what it should be, I do need to get a manual. Anyone run into a similar problem that can shed some light?
Did you try reseting with a code reader or disconnecting the battery? And check your fuses?
I did disconnect the battery and also cleared the codes via jumper wire between plug 4 and 12 and used TRIP RESET button the TRIP/ODO button and press and hold the ENG/MET button. Did not try fuse, guess I should of looked there first. I will take a look and let you know how that turns out.
the first thing you will need is the FSM for this is a Large Section of the book, so you can Properly Pull codes (Ground A to K) and follow the charts.
It could be anything from a open in the Column/clocking coil. but I also suspect that the Seat belt Tightening Pellets went, in fact I'm sure of it. so seat belts need to be looked at.
To Blindly Speculate in a important System Not Recommended. Get the Book and take your time, Or as you said take it to a dealership or a good body shop.
Now your code 42 that comes back to being
Deployment Loop Energy Reserve Voltage Malfunction
Check for a short to chassis ground of the yellow-black wire from pin A4 of the DERM to pin B of the arming sensor, and of the pink wire from pin A3 of the DERM to pin C of the arming sensor. Is the arming sensor new? If not, it may have an internal short.
The code is telling you that the 36 volt power supply in the controller is too low or is dropping too fast after turning off. It should stay up even after the vehicle loses battery power during a crash. It could be that the controller is defective or more likely that something is shorting the supply at one of the two wires from the controller to the sensor, one for the passenger side and one for the driver side.
I'm assuming you used "SALVAGE/USED" parts for the repair. Were these all from the same car? Was it a local purchase or an Internet buy? If you've still got the parts that you removed post a snapshot of them and itemize with the part #'s from the components. Check those numbers against any that you've installed, if different reference them.
I used the email link in your USER ID to send you an email.
Post a list of everything that you DID replace. Was the arming sensor replaced? Might have a GM label 10143543, center dash above DERM I believe. Maybe check the connector if you did.
You only got the one single code?
Update: Clockspring did check good.
There is continuity from derm A4 to E (not B) driver arming sensor and open to ground.
There is continuity from derm A3 to C driver arming sensor and open to ground.
I did notice the plug that is connected to the passenger side sensor has two of the three wires spliced together on one terminal.
Replaced passenger side airbag
Driver side airbag
crash impact arming sensor (was located in engine compartment between blower and frame) 10177901
airbag modulator SRS computer box (derm) 16176558
(was located on passenger side below and to the right of passenger side airbag)
The connector (post #14) looks to be "as intended" - FSM indicates that I believe.
It's possible that the short isn't a hard one with zero ohms resistance, but a "leaky" one with maybe few tens of Ohms.
The problem is fixed. The dual pull arming sensor was bad (GM 10143543 2174). On ebay it is just called an air bag sensor. Besides the dual pull arming sensor there are two discriminating sensors (One on right and one on left side of engine compartment tucked close to firewall). I did get manual for 1994 that did help out a lot. Before I had manual I did check continuity from derm to right discriminating sensor and from derm to dual pull arming sensor. It looks like according to manual error code A42 is either dual pull sensor or short to ground. Thank you for your support solving corvette project airbag issue.
