TPIS header install [part 2]
removed passenger side exhaust manifold
removed starter
roughed-in drivers side header
I would recommend rethreading the headers bolt holes, mine were in need of re-tapping
Here I am in the process of removing the 2 angular braces -see my thread.... TPIS header install[part 1]
Here is the drivers side header roughed in.
The dipstick tube did not come out for me. Here is where it enters the oil pan (long skinny tube covered in grease at the bottom)
I just unhooked the dipstick tube(by bending the hook) from the header bolt in order to remove the OEM exhaust manifold. Whether or not I need to remove it before installing the passenger side header will be determined tomorrow.
I could not remove the passenger side exhaust manifold without removing the starter. did this happen to you guys too?
I'm loading pics now. they'll be up in a sec.
Chuck
Why do I see antifreeze on your oilpan?
Anyway, looks like you're making good progress.
BTW, how you like the finish on those TPIS headers?
Jim, yes I do like the finish. however it's pretty tough putting these things in without rubbing them up againts things and marking them up. I will try to hand buff that marks out after my install.
[Modified by chucks88, 7:35 AM 9/15/2002]
Did you have to pull the starter? I thought TPIS claims their headers fit without doing that, or is that more marketing BS?
