1985 headlights doesn't close
Old Sep 28, 2016 | 02:19 PM
OldsMan's Avatar
OldsMan
Default 1985 headlights doesn't close
Hi,
I bought my '85 on this Saturday, and I already found an issue.
The headlights opening when I pull the light switch but stays open when I push the switch back.
I replaced the the 3 relays , I hear the "click" from the relay when turning off the light.
Do you have any idea where can I start diagnose it?
Old Sep 28, 2016 | 03:13 PM
Kevova's Avatar
Kevova
Wiring diagram? I would check power and ground at headlight motors with lights on and off.
Old Sep 28, 2016 | 03:28 PM
OldsMan's Avatar
OldsMan
I'm waiting for my shop manual - ordered on Sunday, but because I'm in Belgium it will takes few weeks to received it.
Do do you agree if the headlights door opens the motor should be OK and the problem is somewhere in the wiring?
The previous owner did something , (I bought it from the UK ) now the backlights has yellow turn signal what originally was red.
Old Sep 28, 2016 | 04:44 PM
Hooked on Vettes's Avatar
Hooked on Vettes
Originally Posted by OldsMan
Hi,
Old Sep 28, 2016 | 08:16 PM
Hot Rod Roy's Avatar
Hot Rod Roy
That is a perfect description of dirty limit switches inside the headlight motors. Here's a link to another post. You may be aware that the '84 - '87 headlight motors are a totally different design than the '88 - '96 Corvette headlight motors. They have different problems!
corvetteforum.com/forums/c4-tech-performance/3863051-1986-headlight-motor.html
Old Sep 29, 2016 | 12:01 AM
OldsMan's Avatar
OldsMan
If one of the motor has dirty limit switch that can affect only that motor?
So in my case I have to clean both?
Old Sep 29, 2016 | 02:18 AM
Hot Rod Roy
Oops! I didn't understand that BOTH of your headlights are failing to close at the same time. You are right. My suggestion doesn't make sense.
The only thing that is common to both headlight motors not closing is the headlight switch. Test for 12 v. at the LH motor grey wire with the switch OFF. The motor ground is the dk green wire on both motors, but the LH and the RH motors have separate ground paths, so the problem can't be the ground connections.
The relays will still "click" when you turn off the switch, but if 12 v. is missing from the LH motor grey wire, both headlights will stay open.
You could apply 12 v. to that grey wire to test. HEADLIGHT SWITCH MUST BE OFF FOR THIS TEST!! KEEP FINGERS AWAY FOR THIS TEST!!
Old Sep 29, 2016 | 03:30 AM
OldsMan's Avatar
OldsMan
I'll try it on this afternoon
The light switch should be off but what about the ignition? Or doesn't matter with direct 12v?
To 1985 headlights doesn't close
