Hello, I pulled a code off my 87 corvette but im not sure what it means. I short the A/B connector pins and receive the 3 code 12's followed by 4 short flashes, long pause, 4 short flashed.... so if someone could direct me to what code this is that be great.. thanks or I may have a tech 1 back at the old mans house. but let me know, Thanks!
When you saw the 4 flashes, was there a short pause between them? A long pause is indicating that whatever error code is present, it is a repeat. Could the flashes actually be a "22" which would be two quick flashes, a very short pause, and two more then repeating that twice more? There is no code "4".
I don't do YouTube so I didn't check out the video - didn't see the NEED. I thought the OP likely had a 44 all along. It certainly seemed to be - I kinda ignored the OP's post originally when he apparently mention Father as "old man" - that doesn't cut it for me.
Very helpful
Change your o2.
