1985 Corvette L98 Engine Questions
Please help with any ideas. It seems I keep dumping money into this L98. Can an LT1 be dropped in? Do they sell new L98's in crate?
This corvette was left to me in my Father's Estate, in my youthful naiveté I gave away all his other cars, including two Grand Nationals (I'm still sick). Selling this one and replacing with another is not an option. Please advise, can anyone reputable rebuild this thing for a reasonable cost in lieu of buying a new crate engine?
Go to a dark garage and try get it to run. If it runs, you are lucky and you can remove one plug and put in a known good plug and see if the flame is blue. Do it for a few plugs to be sure.
Check fuel pressure and see what it is when you turn it on without the crank. See how long it holds. Before that, check the fuel pressure regulator hose. Remove it and see if it smells of gas.
Let us know what you find. In the meantime, get a Factory Service Manual or FSM and get a SCANNER. SCANNER and NOT a Code reader which is a glorified paperclip
Check vacum to regulator and regulator diaphraghm.
The spark plugs was replaced along with new acdelco wires. I did not replace the cap or rotor. The fuel pump was replaced years ago, and would grind at times. The Fuel Filter was just changed a month or so ago. I did purchase a pressure gauge, so I can check that during daylight. I have the shop manual, and will have to look into the fuel pressure regulator as I am unaware where that is located. I will also need to lookup where/how to check the vacum to regulator and regulator diaphragm. This sounds promising. I appreciate your pointers, you guys are my goto resource! I'll let you know how I make out
Check you fuel pressure regulator, if the diaphragm splits fuel can go through the vacuum hose to engine.
Check the oil for gas smell, are the vacuum lines dry.
There is nothing wrong with an L98, the 85 even has TRW forged pistons standard and should do around 200,000 miles before needing to be freshened up, I ran 9psi boost on my 85 for 8 or more years.
I replaced it at 170,000 miles for a 383 engine but the L98 could have done many more miles.
any codes? how old is the fuel filter? fuel pressure test - key on, 42psi - drop to 37 after 2 seconds? any fuel at the fuel pressure regulator vacuum line? second guessing here, but i'd start with the fuel system. start with the fuel pump, and work you way back. pay special attention to the FPR. if everything checks out OK, move on. double check all vacuum lines. pull the throttle body and give it a thorough cleaning. pay attention to the IAC valve and TP sensor. is the emission system intact (smog pump, cat, EGR valve, etc.)?
any service history? how many miles on that 85? with proper care, the L98 should be good for 300K, so I wouldn't even think about replacements engines at this point. sort through the issue, or issues at hand - remember, that puppy is 30+ years old. good luck - keep us posted.
The repair went well and lasted around two hours mostly spent on wire-brushing the filthy assembly. Upon completion, she fired up one crank! Although the torque has increased, when flooring the peddle on the highway gas can be smelt. -- I feel there must be a vacuum leak as eluded by some members.
In an attempt at getting this conveyance to one hundred percent by solving the problem previously indicated, I hope to replace the hoses connected to the diaphragm and the fuel pressure regulator.
Any additional comments will be appreciated with emphasis on gas smell when fully accelerating, low RPM while stopping rapidly which may cause a stall, couple that an intermittent irregular idle. Thanks in advance.
Below please find the recorded process taken for ones viewing pleasure.
