Steering rack replacement question.
Old Sep 15, 2002 | 11:14 PM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default Steering rack replacement question.
I probably need to replace my steering rack assembly up front.
I've seen rebuilds available on the net. More to the point, I've seen Z51/Z52/Z07 rebuilt units available.
My question is, can I buy a Z51 rebuild and install it on my FE1 car with no other parts needed? Or will I need a few other parts?
Old Sep 16, 2002 | 01:13 AM
JonM's Avatar
JonM
Default Re: Steering rack replacement question. (Matt Black)
You will have a FE1 suspention with a Z51 steering rack. If you want a complete Z51 you need different shocks, different spring...ect
Old Sep 16, 2002 | 01:40 AM
VetteRacer282's Avatar
VetteRacer282
Just a difference in ratio, no size differences. We had a rack replaced in our 88 and they put the wrong ratio in the first time :mad Got the Z51 ratio put in after that..
Goodluck
Matt
Old Sep 17, 2002 | 01:53 AM
Wadoka's Avatar
Wadoka
Default Re: Steering rack replacement question. (VetteRacer282)
Alrighty then.
I may be heading for the twitchier, faster ratio then. Just for kicks.
~other Matt
Old Sep 17, 2002 | 07:53 AM
Joe C's Avatar
Joe C
i just replaced my z51 rack in my 85. got a ac delco rebuiltt from the last detail. price $222 + 13.50 s/h and 150 core charge. this was the best price on a delco rebuild uni that i found. installation was not bad except for the flare nut on the larger hose - had to get a 18mm flair nut wrench from my local napa dealer. one of the forum members has a good write-up in the c4 tech section on steering rack replacement. hope this helps -
To Steering rack replacement question.
