Need LT1Edit guru's inside...
Old Sep 16, 2002 | 01:08 PM
Bravery's Avatar
Bravery
Default Need LT1Edit guru's inside...
I made a log of the vette this weekend and wanted to compare it to other stock 95 auto owners. My two main concerns are the fan on/off temps and the trans shift points. I can email the file to you if desired.
My fans are set at 217 and 224, seems hot to me.
Trans shift points are 41, 77, 138.
Thanks!
Mike
Old Sep 22, 2002 | 06:14 PM
Bravery's Avatar
Bravery
Default Re: Need LT1Edit guru's inside... (Bravery)
**** UPDATE ****
Just got back from tuning the car with LT1Edit. Had an experienced person with the software make some changes to the vette. Car runs cooler, shifts harder, and is vastly improved over stock. Details below on what was changed...
shift points revised:
1-2 @ 39 (41)
2-3 @ 75 (77)
3-4 @ 132 (138)
cooling fans turned on sooner:
195 (217)
210 (224)
line pressure increased 15% at WOT
line pressure increased 10% across the board
These few, subtle changes resulted in a better feeling car that not only runs cooler, but performs better. :cool:
Now I have to take the car over on monday night to get the exhaust installed on Tuesday. Pics and details to follow.....
Mike
[Modified by Bravery, 5:16 PM 9/22/2002]
Old Oct 7, 2002 | 11:01 PM
BAdAzZV8's Avatar
BAdAzZV8
Could you send me your .bin file so I could check out what kinds of things were changed for your shifting firmness? shundog@ufl.edu
Old Oct 10, 2002 | 03:50 AM
Bravery's Avatar
Bravery
Default Re: Need LT1Edit guru's inside... (BAdAzZV8)
I have posted the file on my website at the below address. Hope it helps you out.
I did not make the changes to the program, the knowledge came from Jody Creegan out of Maryland. His knowledge of the LT1 is highly impressive and I wanted to make sure he got recognized for his help on my car.
http://mywebpages.comcast.net/prpl95c4/program
Mike
To Need LT1Edit guru's inside...
