Will these gears work?
Old Sep 17, 2002 | 12:41 AM
Rob 93ZR-1's Avatar
Rob 93ZR-1
From: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Will these gears work?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1859073730
Sorry if it's the most pathetic question of the day. I just don't know if all Dana 44 ring and pinions are the same. Thanks in advance.
Old Sep 17, 2002 | 04:40 AM
STL94LT1's Avatar
STL94LT1
Default Re: Will these gears work? (Rob 91Z07)
No they will not work, and no all Dana 44's are not the same. Corvettes use a Dana super 44, this gearset uses a larger pinion.
Old Sep 17, 2002 | 08:29 PM
Rob 93ZR-1's Avatar
Rob 93ZR-1
Default Re: Will these gears work? (STL94LT1)
Are these super dana 44's Corvette only, or is there other cars they came stock in? Thanks.
To Will these gears work?
