Brake Pad Back Plate Question
Old Oct 30, 2016 | 10:05 AM
HandsomeMike's Avatar
HandsomeMike
Default Brake Pad Back Plate Question
I've had a clicking noise coming from the rear of my 89 for a while that was rather faint and sporadic. I did a track day at NCM in August and since then it's become more pronounced. Yesterday I checked everything from spindle nuts to trying to shake my wheel holding it in the 12 and 6 position and then noticed the metal back plate that clips onto the rear brake pads were falling off the pads and barely holding on! I put a little silicone on the back of the pads and reattached the plates on the driver side and when I moved to the passenger side I found that the back plates were gone! Is this going to cause a safety issue or will it just be a nuisance due to the clicking noise it generates? After reattaching the plates to the driver side I had a neighbor walk behind my car and tell me where the noise was and he said passenger side rear which is the side that has no back plates. Thoughts?
Old Oct 30, 2016 | 11:38 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Get a set of new pads.. It's not worth chancing it..
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Oct 30, 2016 | 11:49 AM
HandsomeMike
Is it a safety hazard not having them on there? What can go wrong? Not being sarcastic, I seriously want to know what can happen.
Old Oct 30, 2016 | 01:18 PM
Aardwolf's Avatar
Aardwolf
The thin strip of metal on the back? Take them off and toss. Those are for anti-rattle. If the thick metal backing is separated from the pad material block I would replace them.
I tried using HPS for track pads and thought I would die. Their heat tolerance wasn't up to Road America. Everything probably got very hot in your brakes!
Old Oct 30, 2016 | 02:01 PM
HandsomeMike
Would the lack of shims cause the pads to vibrate and cause a clicking sound when moving? I don't think it's u-joints. Everything is tight.
Old Oct 30, 2016 | 04:25 PM
Aardwolf's Avatar
Aardwolf
Yes it could but there are a bunch of other things too. Try lightly applying the brakes and see if the noise is still there. It's fine to drive it a little with them dragging.
Other ideas, nail in tire, sway bar, diff or c beam, toe rod, etc etc
To Brake Pad Back Plate Question
