93 Vette injectors
Old Nov 1, 2016 | 04:15 PM
SamRieger's Avatar
SamRieger
Navigator
Default 93 Vette injectors
Did a panic stop and it sputtered and died, would not start again. no spark, new coil and it starts and runs 2 or 3 second and dies. Noid lighted all connectors and all of them pulse but only when peddle is being pressed, pulse stops when peddle is coming up. told to check all injectors for resistance, and if I did this correct, I pulled connector off touched both prongs, one lead to one and other lead to other, meter went up high and then came down to 0.11 on all of them. What else may keep it from pulsing all the time??
Old Nov 1, 2016 | 06:27 PM
antfarmer2's Avatar
antfarmer2
Not sure but thought they should be about 16 call Jon at FIC fuel injection connection. I would look at your o2s and water temp sensor on the water pump as well. Might just be a bad connection there.
Welcome to the forum.
Old Nov 1, 2016 | 07:03 PM
SamRieger's Avatar
SamRieger
Navigator
Old Nov 6, 2016 | 04:15 PM
SamRieger's Avatar
SamRieger
Navigator
Originally Posted by SamRieger
Codes come up as follows C12, 4-H4, 7-error, 9-H64 and H72,
\ Pins a&b blink 1-(1&2) I assume that's 1-12, Still starts and runs only if I keep pumping peddle
Old Nov 6, 2016 | 04:16 PM
SamRieger's Avatar
SamRieger
Navigator
To 93 Vette injectors
