My differential is shot!
Old Sep 17, 2002 | 01:51 PM
VetBoy89's Avatar
VetBoy89
Default My differential is shot!
The Vet went in to the shop on Wednesday because of a weird noise in the transmission and a leaky differential.
The mechanic says the differential is completly shot and needs to be completly rebuilt. I have an aftermarket warranty that will cover the repairs.
My question is should I change the gears from 3.07's to ??? Also, should I have him install a new TC while he's in there, the one I have is stock.
It's my daily driver and I spend about 120 miles on the highway everyday so I don't want to totally kill gas mileage or rev to high while cruising.
Thanks in advance for the input... :seeya
Old Sep 17, 2002 | 01:57 PM
TreyZ28's Avatar
TreyZ28
Default Re: My differential is shot! (VetBoy89)
gears = funnest mod ever!
but the sprayed stroker might be overtaking it :eek:
Old Sep 17, 2002 | 03:10 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: My differential is shot! (TreyZ28)
3.07's are generally the best gear to have for the L98's... anything higher and you'll get going quicker from a light, but the motor will be out of it's power range too quickly. For a daily driver I'd leave the 3.07's in there.
Old Sep 17, 2002 | 03:27 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: My differential is shot! (Springer's LT4)
Keep the 3.07's. Put in either a Yank Stealth 2600, B&M Holeshot 2400, Vigilante 2600, or the GMPP 2100 (Factory for 85 corvette's). All 3 of those are lock-up style, so your gas mileage will stay the same. I have the Y.S. 2600 with 3.07 gears...let me take you for a ride. :D you'll want the same converter. :crazy:
To My differential is shot!
