1986 C4 with not quite 40,000 miles. I am experiencing bad slippage in 2,3,4 gears whether overdrive is engaged or not. I do not smell clutch. Is it possible that the overdrive unit is slipping rather than the clutch?? Thanks in advance for your help.
The OD unit has a sprag in it that would provide direct drive even if the OD was bad. Sounds like the clutch is bad.
Kinda low miles, IF accurate. Change the filter and fluid, ensuring proper type and level. Does the O/D light go on and off? Is it going in/out of O/D?
As far as I know, the OD uses a clutch pack in both OD and direct drive. I'd make sure it's full of clean fluid. If it's 40K and never been touched, that would be a bad thing.
Last time I drove it I had a difficult time getting the light to go on or off and getting to go in or come out of OD as well. Carfax says the mileage is accurate but I have no way to confirm. Thanks for your help!!
The question of a clutch pack or not is what I am really having to wonder. I spoke with a local trans. shop and might as well have been speaking Chinese. I have never serviced the OD, but I haven`t put many miles on the car. Thanks much for your input!!
You do want to make sure you have fluid in the unit. Regarding the OD light, there is a relay (same as the fuel pump) in the area above the master cylinder. Cost about $12, replace it or check the wires.
If the car goes in reverse and the vehicle moves the OD clutch plates are OK, assuming your clutch is good and not slipping as you indicate.
Suggestion; put the car in 3rd or 4th gear, OD off, can you move the car or does the clutch slip badly.??
Agree. My '84 4+3 just rolled over 36k miles. I changed my fluid a couple months back.
I am certain the previous owner changed it at least once before but no idea how many miles it had been since that change.
I could not believe how disgustingly dark brown and thick the fluid had become. Hard to believe that GM recommended 30k changes.
Hi Frank, It moves fine, just slips under semi hard acceleration in every gear but first. No problems with reverse. I am thinking that the problem with it going in and out is, like you mentioned, tarnished or corroded electrical connection somewhere. It had began to slip long before I had the problem with engagement. Thanks again for your help!!
I bought a 88 4+3 a month ago. Previous owner said it needed a clutch. So I ordered a clutch kit and put it in,( yes it needed it badly.) I have bleed the system as told by the shop manual. I still have to pump pedal several times to get it in 1st and 2nd, then a few more times to get it to roughly go into reverse. Let out on clutch about 2 inches and the car starts to move then the clutch slips and won't back up. But it will move forward. I haven't made it out of the shop yet. This is very frustrating probably as some of you know. What is wrong with this thing? I own a 79, a 85, and now this 88, never encountered this issue before. Please help. Thanks.
That makes sense for a worn clutch. Most cars with clutches going out only experience slipping when the car is under load. 1st gear is short enough not to recognize a slipping clutch, but the other gears for sure would reveal it. You can pull the slave cylinder boot off and get a camera in there to inspect. But clutches are just like brakes: the materials time out, get hard, etc. Things time out and simply need to be replaced.
