engine compression question
Old Sep 17, 2002 | 06:51 PM
DarkHalo's Avatar
DarkHalo
From: SCMR Rat Pack'r Charter Member, Inland Empire Chapter
Default engine compression question
Heres a Q for you engine gurus. I have a '91 L98 stock engine. My manual says the engine is 10.25:1 compression but the "Portable Vette" says the '91 L98 is 11:1. Plus it said the '90, which is rated at the same HP as the '91, is 9.5:1. Are these typos? BS? or smoke and mirrors?
Old Sep 17, 2002 | 07:39 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: engine compression question (DarkHalo)
The '90 Vette picked up 5HP over the '89 due to a cam change and CR increase (I believe the pistons were no longer dished); I thought my CR was 9.5:1 with the dished pistons. The '91 Vette had the same HP ratings as the '90, according to the "Corvette Black Book".
I would trust the data from your manual; considering the gain was only 5HP an increase of 0.75 seems more likely than one of 1.5 in the CR.
