87 Red Hot Cat
Old Nov 10, 2016 | 03:58 PM
Tom454's Avatar
Tom454
Default 87 Red Hot Cat
Got engine started after top end cleanup. TPS is not set and timing is set to where it was before I tore it down. I know it needs adjusting. Timing can't be too far off. It is running rich. I ordered the TPS pin breakout "tool" but it hasn't arrived yet.
Only ONE cat (drivers side) is red hot, the other is normal temp. Likely cause for only ONE side to burn hot? It wasn't doing this before I tore it down so I'm hesitant to blame it on a clogged cat.
Old Nov 10, 2016 | 04:51 PM
Square's Avatar
Square
I have a late 86' (Aluminum heads). It might be an injector on the one side is partially clogged open, and thus dumping more fuel on the one side which would leave excess fuel vapor to burn in the cat and help cause the rich smell??? That is all I can think of off the top of my head.
I can't think of a reason the TPS would cause only one cat to glow. Usually it is a clogged cat (as you know).
Old Nov 12, 2016 | 04:02 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Hot exhaust is a sign of fuel burning while the exhaust valve is open.
Late timing, rich mix will attribute to this effect.
87 is a bank fire engine I believe O2 sensors on each bank.
Old Nov 12, 2016 | 09:00 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Old Nov 12, 2016 | 05:07 PM
Tom454's Avatar
Tom454
What are the chances the O2 sensor is any good now? It looked like Rudolph's nose.
Old Nov 13, 2016 | 02:30 AM
JrRifleCoach
Only one way to find out.. Buy a new one.
Old Nov 13, 2016 | 08:11 AM
Tom454's Avatar
Tom454
Yeh... I figured I'd end up doing that anyways.
Old Nov 13, 2016 | 09:57 AM
aklim's Avatar
aklim
Really? IIRC my 91 is bank fired and I have only 1 O2 sensor
Old Nov 13, 2016 | 10:54 AM
Gibbles's Avatar
Gibbles
I had that happen on the car i had in highschool, mazda rx-7.
plugged cat, the car also burned oil by design. I'm sure that did not help cat converter life.
I went through cats just about yearly, loss of power and a glowing exhaust system.
I'm always a little fearful of a plugged cat after my parents lost a minivan due to fire and a plugged pre cat.
Pretty much they parked the car and about 20min later the car was in flames.
Old Nov 13, 2016 | 03:46 PM
383vett's Avatar
383vett
Op, you don't have to wait for the TPS jumper to check the tps voltage. Just use 3 1" wires with the insulation stripped in different positions to avoid shorting and connect your multimeter between a and c (if memory serves me right).
Old Nov 13, 2016 | 04:45 PM
aklim's Avatar
aklim
If it were me, I'd return that jumper and spend the money on a scanner which works much better
Old Nov 13, 2016 | 05:43 PM
Tom454's Avatar
Tom454
I plugged in a scanner .... no codes. It won't even idle. Have to hold the throttle to keep it running. VooDoo.
Old Nov 13, 2016 | 05:44 PM
Tom454's Avatar
Tom454
The gizmo made it real easy read the voltage. The TPS is bad.... ordered a new one.
Old Nov 13, 2016 | 05:52 PM
aklim's Avatar
aklim
Codes are set for outrageous values. So in the middle of the Sahara at the hottest time where it is 120 degrees, if the ECM sees 20 degrees it would not throw a code. The scanner sees what the ECM sees. You determine if the value is correct.
Old Nov 13, 2016 | 05:54 PM
aklim's Avatar
aklim
The gizmo is an expensive one trick pony. The scanner can do all that and much more
Old Nov 14, 2016 | 10:54 AM
Tom454's Avatar
Tom454
I have a scanner.... it didn't help. Maybe I need a laptop computer program instead.
Old Nov 14, 2016 | 10:56 AM
aklim's Avatar
aklim
Doesn't it give ECM data or just codes?
To 87 Red Hot Cat
Old Nov 14, 2016 | 11:40 AM
ddahlgren's Avatar
ddahlgren
If the scanner does not give real time data it is just a glorified code reader and useless. You can replace that with a paper clip. When I bought mine on 2008 my second purchase was a scanner that gives real time data to make life much simpler. It answers a ton of questions in minutes rather than hours.
Old Nov 14, 2016 | 11:42 AM
aklim's Avatar
aklim
Kinda why I am thinking he got a paper clip in a fancy container as opposed to data feed.
Old Nov 15, 2016 | 03:52 AM
Tom454's Avatar
Tom454
That sounds about right.
