How do you disable a 92' antenna
Old Sep 17, 2002 | 07:20 PM
VET 350's Avatar
VET 350
Default How do you disable a 92' antenna
I want to disable my antenna on my 92'.
I don't ever listen to the radio.
Thanks in advance
Old Sep 17, 2002 | 07:39 PM
mjfox's Avatar
mjfox
Default Re: How do you disable a 92' antenna (VET 350)
disconnect antenna relay at the back left under the bezel
Old Sep 17, 2002 | 09:39 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
If you remove the hatch trim at the rear, you'll come across some foam. Buried in the foam is the antenna cable and the wires for the power, simply unplug it.
Old Sep 18, 2002 | 10:37 AM
Austin89's Avatar
Austin89
Buy the bypass switch from MAD for $15, it takes 20 min to install.
That way you have the radio if you ever need it for some reason.
I hated how the antenna looked on my car, I never see it anymore.
Old Sep 18, 2002 | 03:26 PM
Carroll B's Avatar
Carroll B
If you can use a soldering iron, go to the mid america site and download the instructions. Buy the switch at radio Shack for $3 and it's a 20 minute job. I mounted my switch on a small bracket in the center console using a hot glue gun.
To How do you disable a 92' antenna
