Ride quality and tire pressures....
On most of my cars the tire pressures usually wind up at 30 to 32 psi for street use. I arrive at that by starting at a value (usually about 32 psi) and checking for contact patterns and after more time the wear patterns and make adjustments.
There are some extremes too. My S10 is very light in the back, so it wears the centers quickly unless the pressure is dropped. I went with bigger wheels and tires on it and it made it worse. I had to lower the pressure again. Another issue was when I went to 255/50/16 Michelin tires, they were so stiff that the truck rode bad and felt like it was skipping off of every bump. Lowering pressures did not help much. The tires were just too big and too stiff for that light weight.
Discount Tire Direct has given me problems about load rating and tire sizes several times. On my '95 they would not sell me a set of 275/40/17 tires, on my S10 they would not sell me 235/55/16 tires, on my '96 Caprice they would not sell me 235/70/15 tires, all because they said it was not the right size. In all cases I argued with them and they discovered they were wrong and these were the stock sizes. They also told me the load range was incorrect for the car and they needed the stock rating or greater to be safe even though I was buying a tire that was larger than what they were pushing. Their tire data is frequently wrong!
I was responsible for the engineering specifications and quality of the tires when I worked at an auto manufacturer, so I frequently don't agree with some of the things that are being said by the tires stores as fact. It is still hard to convince them.
Good luck with evaluating your tires and getting the pressures set.
But with very high speeds, another challenge becomes heat buildup from the energy being reacted through the flexing carcass. So it makes sense that at very high sustained speeds, a higher inflation pressure will keep the tire from going boom. As a related side note, in Formula 1 racing this year Pirelli (who makes their spec tires) implemented a rule that sets a minimum cold pressure for their tires. This was because some tires flew apart during races for no apparent reason other than heat and insufficient load capacity. The teams are pissed because the tires have less grip and a very narrow sweet spot for running in the proper heat range, but at least Pirelli doesn't have to explain exploding tires. So yes, there can be a tradeoff between the pressures for best heat tolerance and best grip.
Along the DiscountTireDirect comment where they avoid selling a tire/wheel combo not designed for a given car, this isn't uncommon. Back in the early 2000's, Nitto made a non-Z rated 275 40 17 that was "all-season". I had to remove my wheels and have the tires mounted off the vehicle. Basically, corporate policy is avoid selling a tire with a lower speed rating than the car is capable of -- because they can't know how the car is used.
I always thought the higher pressure ratings in the door jamb were to prevent blow-out during extended use at high speed. Of course, we don't KNOW what speed they had in mind.
After running those Nittos I talked about (which I hated), I ended up going back to a Z tire. I also went to 11" rims with 315 rears -- due to grip dissatisfaction. (Of course the original Gatorbacks were still on my 89 car in 1999 AND lower speed rated tire categories have firmer rubber compounds to achieve higher mileage ratings.) In short, I might not have given 275's a chance because of my tire age/selection. That said, the 315's are probably the "right size" because I converted to a 383 which added more grip challenge.
In riding the fence between firmness (30-32PSI) versus ride (26-28PSI) for the past 10 years, I've found advantages to each....also frustration.
Even in the 28-30PSI range, my first set of Sumitomo 315's wore more in the middle than the edge. I thought this odd. Now, I'm on my 3rd set -- which seem to be wearing more evenly -- even after letting pressure slip near 20 last winter. I'm at a loss to figure out why the middle wore faster on that first set.
I've never been happy with 70+MPH balance. I even had tires road force balanced. I have almost always been able to note vibration above 65-70. I finally decided local road/hwy condition was part of the issue.
At the same time as my 3rd set of Sumitomos were mounted, I installed new wheels, ball-joints, bearings, bushings, tie-rod ends, rear toe-bars, and (later) heim rear dog-bones. Finally, after over 12 years of ownership, the vibration seemed gone. When I did feel it, I confirmed road condition cause it (by retracing my path and observing WHERE the vibration occurred).
That said, it's coming back. I guess it's time to check balance again...though mileage probably isn't more than 5k-10k on the tires. It's still intermittent -- but there. My point here is that lower pressure reveals imbalance more. If I run my partially worn tires at 26 PSI, I can feel more vibration than at 32PSI. At 32 PSI, I think most/all of the vibration is road induced. At 26PSI, the mammoth width of the 315's can't entirely be overcome.
I'm saying wider tires can't stay perfectly round/balanced for long. Compared to thinner tires, you may run into dissatisfaction with hwy vibration by choosing the lower-pressure option. And, once worn, you may not be able to rid yourself of vibration (due to inherently uneven wear of any tire). Knowing this will help you decide what pressure might be your preference.
From my personal observation (over 17 years of ownership), I feel an aversion to running above 30 PSI. When I bought the car, the PO had the Gatorbacks blown up to 45PSI which was the max rating stated ON THE TIRES. As noted by another owner, it's just WRONG to run max on the side of the tire -- without looking what the car is designed for.
I think lower pressure is fine but you have to check it more often. It's easy to dip down to 20 when you start at 26. I think it's also easier to wear tires unevenly at lower pressure. (This is mostly a guess based on personal observation + knowing about heat buildup in lower pressure tires).
With 275's on the front and 315's on the rear (of a standard base suspension) 89, I really think 28-30PSI provides the best all-around comfort vs performance. Above 30 is better when driving hard. Below 28 runs into the problems I talked about regarding longterm wear...long with perception of vibration problems as the tires wear.
I'm sure this may be different depending on roads in your area. I think overall quality of roads have gone down in conjunction with governmental funding problems. This may also play a factor.
PS. I should add that I only have 80k on my 27 yr old car. It was age that made me decide it time to redo the suspension.
I have always had rear tire center wear, especially on 315s, and I have tried various pressures, from high 20s to high 30s. I usually run the rears around 32, and fronts around 35, for better rear grip/ride, and front steering response. Remember there are other factors too, breaking, MPG, and with larger wheels and low profile tires, the low pressure may make the wheel more prone to bending/cracking. I run my C5Z with HRE's w 35 all around to prevent wheel damage.
On my Passat the low pressure light will come on if it goes under 32.
*'80's F-bods where I ran the "legendary" 245/50-16 tires on stock, 16" rims (GTA or IROC) (right sized tired for the rim)
*My stock '06 C6 which IIRC ran a 285/35-18 on the stock rim (right sized tire for the rim
*Now on my '92 with '04 Z06 wheels I'm running the 295/35-18 which is the stock/right sized tire for the rim (C5 Z06).
All of the above was with a variety of tires/brands over many years -even decades.
I am running Continental Extreme Contact DW 285/40/17's on all four corners and I just reduced the pressure from 35 to 28. Quite a difference, car is much less darty as well!
I think that inflation pressure on wide, low profile tires has everything to do with sidewall construction. The sidewall is what decides speed rating and load capacity. Too little pressure is going to compromise sidewall support. This is part of the reason you want a higher pressure for performance driving. Of course, in straight line racing, the lower pressure in rear tires is an advantage, but then there is no real cornering stress, and the run is short enough that heat is not really the issue. But when talking road course or autocross, it's an entirely different ball game. Sidewall flex is a dangerous enemy as well as heat. A firm sidewall in cornering will help to maintain a better contact patch on the track. Also keep in mind that there is greater down force pushing on the car at higher speeds.
My '96 called for 32 psi for normal driving and 35 psi for performance driving. Lowering the tire pressure for a smoother ride is always an option, so long as the driving isn't 'spirited' for any length of time. Remember sidewall integrity. The C4 was always known for it's stiff ride, especially the Z51 cars. Personally, if it's a softer ride I'm looking for, I'm going to look at shocks before reducing tire pressure below recommendation.
THAT SAID....This newest set SEEMS to be wearing a LITTLE more evenly though I noticed something today...
I have a new 315 Sumi in my basement. In looking at the profile, it's rounded on the shoulders. IOW, it's molded lower on the outside than the inside. Even when mounted and inflated, this may contribute to faster wear in the middle.
I have run lower pressures on two sets in the past....averaging in the mid 20's when you consider leakage/shrinkage. Around town, I would declare mid 20's pressure safe for the sidewalls. But, I never drive mine out-of-town (on the hwy) where tires could develop more heat.
I imagine that just normal driving around town at lower pressures isn't going to cause too much havoc. However, it is that psi that attaches the tire to the wheel, and with that torque monster you have, I'd be concerned about that wheel starting to spin faster than the tire...lol
Well played, Chris!
....Worn in the middle.
I just lowered the pressure to 28, i had issues with the center wearing out on the old rears.
My ride is so harsh with the 84 Z51 package, I'll take what i can get at this point!
Also del-a-lum and banski rods helped with the harsh ride quite a bit...
