Modifiyng my Borla cat back system
Good evening,
I am planning to improve the sound of my cat back system.
Therefore I want to open the middle muffler and put some straight V2A pipes covered in heat resistant insulation wool in it.
The goal would be a louder agressive tone at full throttle while not being too loud at low speed.
Has anyone tried this before and could tell me about his result?
I am also thinking about switching the LT 1 look endpipes to four round pipes. Did anyone do this? Which pipe size matches well? Maybe it would be possible to see some pictures.
Thank you for your advice and best regards from Germany. Markus
Hello, yes I know this problem.... I would be interested how my modifications on the middle muffler would change the sound, maybe it gets better or worse. My idea was to reduce the drone noise by using insulation wool and to get an deeper tone by using not perforated pipes.
So you're looking for quiet at low speed, loud at WOT, and no drone. I'm thinking you're only gonna find one manufacturer that meets these requirements.
The Corsa system is nice and sounds good but 1200 for a cat back system for a 7 to 8 k is a bit over the top in my mind.
I suspect a lot has to do with the car design.
Borla makes inserts that go in the pipe before the mufflers to reduce the drone. I believe they call them venturi's or something. I have the borla catback and modified mine to eliminate the drone. I basically copied corsas design. I did a write up on it.
Link PLEASE !!!!!!!
This is it:
https://www.corvetteforum.com/forums...xperience.html
This is how it sounds taking off:
I'm putting headers, eliminating the pre cats, and putting a high flow cat on this weekend so I will do some more clips afterwards. I'm sure it's going to get louder. Right now at cruising speeds the iPhone decibel meter shows around 75 decibels in cabin.
Moderators where did the latest post vanish to? Menu says it is there yet all I see is the one I posted hours ago previously
