Hard start problem, Need some help
Old Dec 21, 2016 | 03:19 PM
Lt4-396's Avatar
Lt4-396
I went from pin b6 black which is supposed to be the ground for the ect sensor and I'm not getting any resistance and no continuity which from what I understand I should be, so would that mean I have a break somewhere in the ground wire from the Ect to the pcm?
Old Dec 21, 2016 | 05:46 PM
1993C4LT1's Avatar
1993C4LT1
That's weird how it reads ambient temp within 30 seconds. When my coolant sensor was bad, it threw a code and I used a scan tool to diagnose it. I just followed the diagnostic in the FSM. Just make sure you're reading temp in fahrenheit, and not Celsius. I say that because I was reading it that way, and it threw me off.
Old Dec 21, 2016 | 06:00 PM
Lt4-396's Avatar
Lt4-396
Yeah that's what was throwing me off but I fixed it, it was a cut, literally cut ground wire. I know the PO had all the work done by a "specialist corvette shop" and that they wanted to buy it. I almost have a feeling they cut the wire for some reason.
Once I soldered the ground wire back together everything works great.
It was just how it would heat up correctly until you shut it off then everything was messed up that really confused me.
Now I just need to figure out why it won't connect to my scanner
Old Dec 21, 2016 | 07:49 PM
1993C4LT1's Avatar
1993C4LT1
Look into using something called blue devil. It's a Bluetooth obd2 connector that connects to the aldl port, and you buy an app for your phone. I have not used it, but have heard good stuff about it. I use something similar on my 93. Not to pull codes, cause I can do that with a paper clip, but to datalog. I believe you can also pull codes with a paper clip on a 96?
Old Dec 21, 2016 | 09:40 PM
Lt4-396's Avatar
Lt4-396
I don't need it to check codes but to get an inspection. In my state NY they just hook a reader and as long as their is no check engine light it passes.
Old Dec 21, 2016 | 10:20 PM
1993C4LT1's Avatar
1993C4LT1
Ah, my bad I misunderstood your post.
