96 Optispark Vent Harness Help!
Old Nov 22, 2016 | 05:46 PM
Indio Monk's Avatar
Indio Monk
Default 96 Optispark Vent Harness Help!
Well I have a LT4 Project Vette that some of you might have followed recently. I have been having a misfire p0303 code that I have not been able to solve.
I almost pulled the Opti todayName:  File_000 (17).jpeg
Size:  1.42 MB but I wanted to see where this VENT Harness goes since one is missing off of the Air Intake near the MAF.
I looked at the one vent hose that comes off the opti itself not the plastic cap (the metal part of the opti) and it is hooked up to the hose that runs to the intake manifold near the PCV valve area. I don't think this is right. I think that the hose from the metal part of the opti is supposed to go to the air intake elbow.
The plastic part (CAP) of the opti right below cylinder 3 #1 is supposed to be where the vent harness hose goes to the Intake Manifold (near the PCV Valve).
If anyone can help That would be great! I looked at pics on line and they show only the original vent harness that is covered in protective conduit.
Hopefully I am explaining myself clearly.
Thanks!
Old Nov 22, 2016 | 06:23 PM
Indio Monk's Avatar
Indio Monk
Right after I posted this I think I found the answer.
https://www.corvetteforum.com/forums...oes-where.html
