Spark Plugs, firing order
Does anybody have a picture of the distributor wire positions?
What spark plugs are good for a normal grocery getter?
Any good or bad rotor and cap brands?
I think I will swap out the plugs, cap and rotor, check the wiring and see if I can not make the thing run right
Any suggestions
Any suggestions
Good or bad for cap and rotor is relative as in good for what use. For a street car for all the stuff listed that I would use, Delco or Standard Motor Products possibly Echlin. The color does not matter black is just fine and no sense in paying for red tan or some other one. The big deal is brass terminals and not paper thin. Wires gut feeling would be Delco nut I put a set on my '91 doing a tune up when I got it and the car ran worse than the originals to check put the originals back on and ran much better so called my buddies at Moroso's engineering dept. and told them what I wanted and they sent a universal V8 set and 1 odd wire. You can do the same at any speed shop or the usual discount mail order places. I like blue rather than black as black is made by using carbon that conducts electricity so not a style thing. You want 8mm spiral core with 780 to 800 ohms per foot. All the other stuff has it's place and that is not your car. Good RF/EMI and conducts easily is what you need. Mine have been on since 1/2009 and still work just fine for what is that is worth same for cap and rotor and it is a driver and goes in hot weather cold weather rain. A dusting or snow is no reason to park it just stay off the interstate or take off the wide tires with shallow tread.
There are a dozen or more brands of plugs. Personally I run Champion for a couple reasons years ago worked with engineering at their place on some projects, I understand their numbering system well and know what to ask for to get what I want. They have been dead reliable for me and the same ones in since 2009 and runs as now as it did then. AC plugs must be good at least in 2002 as I still have the same ones in my Pontiac sedan as new and has 93k miles on them great mileage and fires right up. No idea how good they are now though.
This is all my opinion and not looking to start a rake fight.
Oh firing order 1 8 4 3 6 5 7 2 It does not matter where #1 is as long as order is right and wires reach easily with fewest left right bank switches.
, 1-8-4-3-6-5-7-2. search L98 plug wire lengths and routing - plenty of forum discussions on the subject.
