input on chip and turning for c4
Has anyone put a chip in there c4 n got it turned b4.
If so what kinda chip and what's involved with the turning process. Was it worth it and what's the cost.
A proper tuning process involves you getting the car strapped on a dyno and they make adjustments till they maximized it. Usually about $600 and up NOT including your drive time and other misc items you encounter (food, lodging, etc, etc) to the dyno facility.
Another way that I don't like as much but is somewhat acceptable is to datalog the ECM while it is doing say a WOT and other runs within the curve to maximize it. So you would essentially have to keep doing it till they were satisfied that it is maxed out.
The third way which I won't do is to have the tuner make a SWAG at what the car should be doing based on what you tell them you have for mods. Any reasonable tuner would backpedal and not give you all that there is since there is a liability reason. IOW the safety margin will be larger.
What you haven't told us is what mods you have on the car and what you are trying to achieve.
Off-the-shelf-chips such as HyperTech, Jet and others by themselves really don't do a lot to provide noticable HP/torque gains. And if you even get a tune now, adding mods like headers, cam, heads, and such later on may very well make that tune unsuitable.
You should also factor in the overall condition of the engine, trans, and diff. Hopping up an engine with something like 150K miles on it could spell the end of it if it gets beat on constantly. If you are going to keep the car for some years, start budgeting for rebuilding the engine and the rest of the drivetrain.
If you want to go fast, you have to stop. Go thru the brakes (calipers, pads, and rotors), then look at the suspension. It's gotta handle too.
Seriously, if the OP sets it up right, it can be good as long as he is keeping the car. As we all know, any mod you put in, is money as good a lost. The next guy probably won't pay you for it. If he dyno tunes every time, it is a waste of money unless major groups are done. Say intake and headers or heads and cam, etc. I wouldn't do it just because I put in a new TB or intake. Gain isn't enough to justify cost.
Also find a few good dyno facilities and check them out with people who have used them. Many don't want to tune that old stuff anymore or have the software. Principles are the same but they might not have need for the software since too few do it.
Better question: How much money you got to spend?
