DOH!!!! Need some help!!!!
Old Sep 18, 2002 | 06:12 PM
LT5's Avatar
LT5
Default DOH!!!! Need some help!!!!
A few days ago I started my car and I heard a loud bang and then it died. After that the starter would spin, but the engine wouldn't crank over. After pulling the starter I noticed the shaft broke off and fell in the bellhousing. Doe these cars have a dust cover or some other access besides dropping everything? Thanks!
Old Sep 18, 2002 | 06:32 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: DOH!!!! Need some help!!!! (LT5FIRE)
Which car, the '90 or the ZR1. I am assuming the '90 if you were able to pull the starter. They do have dust shields in front of the flywheel. There is not a whole lot of room once you take it off though. You may be able to use a magnet wand to get the gear and any other large debris out the hole in the side of the bellhousing by the slave cylinder. You will want to remove the slave cylinder too before attempting this route.
Old Sep 18, 2002 | 06:34 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: DOH!!!! Need some help!!!! (Vette92)
Also check the teeth on the flywheel for damage. The starter going out with a bang may have cause a tooth to become marred.
Old Sep 18, 2002 | 06:53 PM
LT5's Avatar
LT5
Its on my ZR1. My starter is in the intake valley and I've already pulled everything out. I've fished with a magnet in the valley opening, but I've only managed to fail. :yesnod:
Old Sep 18, 2002 | 08:17 PM
LT5's Avatar
LT5
ttt
Old Sep 19, 2002 | 12:47 AM
R23HTC's Avatar
R23HTC
If you haven't already, you might also want to post this in the ZR-1 section of the board. :yesnod:
http://forums.corvetteforum.com/zeroforum?id=50
To DOH!!!! Need some help!!!!
