Replacing rotor
Old Nov 28, 2016 | 06:45 PM
JetJock's Avatar
JetJock
Default Replacing rotor
I've been having a slight miss with my 91 L98. I checked the fuel pressure and it is good, I've replaced the damaged spark plug wires and the spark plugs which were the wrong ones installed by a mechanic. I pulled the cap on the distributor and took pictures of the cap and the rotor. The cap looked fine but I wanted a second opinion on the rotor. What do you think?
Old Nov 28, 2016 | 06:56 PM
Churchkey's Avatar
Churchkey
Hard to see with that straight in camera shot but it looks to me like you have arc tracks on the cap contacts.
With new plugs & wires suggest a new cap & rotor = done deal for many miles.
Old Nov 28, 2016 | 07:03 PM
WW7's Avatar
WW7
The caps with the brass contacts are way better then the ones with aluminum contacts..It's hard to tell from the picture if your cap is burned or not , but they're not that expensive to replace both the cap and rotor..WW
Old Nov 28, 2016 | 07:10 PM
JetJock's Avatar
JetJock
Thanks. That's what I need to kmow.
Old Nov 29, 2016 | 10:58 PM
JetJock's Avatar
JetJock
Just FYI. I took the cap down to the autoparts store that I use and the owner looked at the cap. The electrodes on the cap were broken! No wonder there was a miss. Got the new rotor installed waiting on the cap to show up. It has brass contacts. Thanks for the help, guys.
To Replacing rotor
