plug inspections
Old Sep 18, 2002 | 07:14 PM
Austin89's Avatar
Austin89
Default plug inspections
Just got a 100 shot NOS installed.
What exactly do I look for when inspecting plugs after running it a couple of times? Any particular plugs to look at (all?)?
Old Sep 19, 2002 | 05:56 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: plug inspections (Austin89)
Personally, I would inspect #2 before the rest of them. Look for the plug to look ashy, if it does, it is running lean. If it has caked on deposits, it is running rich. If it looks pretty clean, then it is just right. A little ashy is OK. Also check the gap to make sure they are set closer for the nitrous. .035 is recommended normally.
Old Sep 19, 2002 | 06:05 PM
95AquaC4's Avatar
95AquaC4
Pull ALL plugs!! All cylinders do not necessarily burn the same. With nitrous you should look for the following. Detonation will be indicated by black or silver colored specks on the porcelain. If you see this, reduce jet size. If the ground strap is bluish, or rainbowish in color, reduce the jet size. If the ground strap shows signs of melting, reduce jet size AND replace plugs with thicker shorter ground straps. Again...pull EVERY plug. A good tuner would!! :yesnod:
Old Sep 20, 2002 | 12:26 AM
Austin89's Avatar
Austin89
thanks guys :)
To plug inspections
