1984 tach problem
Old Sep 18, 2002 | 07:40 PM
bwalker1947's Avatar
bwalker1947
Default 1984 tach problem
I have a 1984 with a inopertive tach .I found the lead on the tach filter not connected on one end . the other end went to the coil tach side. Now my question is if the tach reads all the way up ( all LCDs lit up ) would this be the missing wire ? if so where is this wire ? could someone send me a small wiring diagram on just the tach filter and wires going off it ?
New and confussed
Barry :
Old Sep 18, 2002 | 07:46 PM
scorp508's Avatar
scorp508
Welcome to the forum. :cheers:
Your tachometer lead plugs into the distributor cap connecting to the bottome side of the HEI coil. With thise unplugged your tach will read 0 at all times. The filter is located on this lead. The lead is a single brown wire. The tach filter looks like a small aluminum cylinder with a screw tab coming off the side of it where it gets bolted into the upper/left bolt on the bellhousing.
Can you explain what side of the lead was busted? Perhaps if it is the side that goes to the distributor and it has grounded itself on some metal it may light up the entire tach. I am not sure.
