Suspension question - Poly in trailing arms with Heim camber and toe rods - binding?
I'm going through the worn out rear suspension in my '87. I'm more focused on lateral performance than I am accel/decel improvement, so I had figured I would go with heim-jointed camber and toe rods, and just upgrade to poly bushings (with zerks) in the trailing arms.
This sounds great on paper, but I'm worried about the combination of those two causing binding in the suspension. Where the rubber bushings all around could accommodate the few degrees of camber change in the spindle as it articulates, now the Heims will force the camber change, and the poly trailing arm bushings will resist being twisted.
Has anyone ever run this setup? Am I making this a bigger deal than it would be in reality?
Thanks for the expertise!
So my car now has poly in the rear (dog bones poly, sway bar poly, toe rods are still OEM) except for the camber rods which are Banski heim rods. After an alignment the car responds very good without any binding that I can feel!
Hope this helps
I actually looked into this for drag(acceleration only). I came across some info that explained the poly rear are better suited for drag because they bind when cornering and heim joint rod end style have more free movement. The poly will be fine in and up/down movement you see in drag vs side loading of cornering. Still from a launch perspective I'd think the rod end would also be better and not compress any, especially with high power. But my build is more of just a budget and I don't plan on going too fast so I'll prob just poly my trialing arms to save $. Pretty much what you have now rod end camber, I'll get rod end toes and install polys in my dog bones.
The problem is the silly design sold as new. Rubber was the band aid to cover it up. The dog bones need to be installed to follow the same arc as the half shaft to not bind with a rigid bearing and they are not. In my mind poly is one of the most over sold patches ever devised as they fail on a variety of conditions. yes they are better than worn out rubber but come with their own problems too.
Pro Mechanic
Yes, there will be binding. Why? As the suspension moves through it's travel, the camber changes; the knuckle rotates when viewed from the rear. That movement is dictated by the axle and the "camber rods" AKA lower control arms. The Dog bones AKA trailing arms aren't designed to twist to accommodate that rotation of the knuckle. They accomplish that movement in the stock set up, with the rubber at each end.
The best poly/heim solution would be spherical bearings in the trailing arms and poly in the lower control arms, since the lateral deflection to the LCA bushing is minimal. The best solution over all is spherical bearings at all pivot points.
Yes, there will be binding. Why? As the suspension moves through it's travel, the camber changes; the knuckle rotates when viewed from the rear. That movement is dictated by the axle and the "camber rods" AKA lower control arms. The Dog bones AKA trailing arms aren't designed to twist to accommodate that rotation of the knuckle. The accomplish that movement in the stock set up, with the rubber at each end.
The best poly/heim solution would be spherical bearings in the trailing arms, and ply in the lower control arms, since the lateral deflection to the LCA bushing is minimal. The best solution over all is spherical bearings at all pivot points.
Thanks all for the input. Sounds like there's general consensus that poly trailing arm/heim camber rod is not a good combo, as I figured.
Looks like by piecing together parts from Banski and VB&P, I can go full-heim in the rear for ~$850. I'll justify the cost to myself as "fixing a design flaw in the original suspension!"
Pro Mechanic
Ideally, I'd want to see spherical bearings on both ends of the LCA's and all 4 points of the dog bones. I'd save money and not care about the toe rod/ends.
Street driven, been setup this way for >15 years, with a recent R&R of all 16 aft Heims. The car is very precise, a stock Vette feeling very loose, by comparison.
Zerks on the F a-arms and lubing the F sway bushings at each oil change, improves the 'feel', deemed less binding of those poly sway bushings.
I have not really noticed a need for the trailing arms, so I didn't prioritize them too high on my to-do list. But I will try them when the competition season starts up in spring, I think. Banski was reducing stock on some items, so if you can't get the trailing arms don't fret too much. Get the camber arms by all means.
Originally Posted by ddahlgren
Are there any dimensions or angles for setting rear spindle when changing so called dog bones / longitudinal links?
So your best starting point is stock. You could experiment from there. The main thing you're going to be impact is rear bump steer. I go a little cross-eyed just thinking about all the permutations of those rear caster angles! You could also go shorter or longer overall on all four trailing arms to shorten or length the wheelbase a bit. But I don't know why one would.
Wow , my post was deleated .Well see how long this one lasts . All this info about poly /rod ends ...
Not one mention of the rubber bushings in the batwing . All the effort spent in bushings and alignment wont mean squat in a lateral situation if the rear end is moving around in 25-30 year old rubber bushings .
Interesting point. In the year that I've been on this forum I don't think I've seen this point raised for C4s. I don't know how much it moves laterally, which is down to the two round rubber mounting bushings for the batwing, as you say. It is well constrained longitudinally and in rotation (around the axles) by the C-beam. Does anyone even make poly or Delrin batwing bushings?
Originally Posted by Tom400CFI
I would piece it together and NOT replace the toe rods.
Originally Posted by whalepirot
all 16 aft Heims
Originally Posted by MatthewMiller
The camber rods are by far the most important
I'm definitely going for poly batwing bushings, and would probably go solid aluminum or delrin if I could find any. The only argument for these being less important than camber rods is that movement in the camber rod actually effects the camber angle, whereas movement in the batwing wouldn't, as the half shaft and the camber rod would both move identically. Still, seems like the whole rear end sloshing around under the car could lead to some scary dynamic behavior, so they'll get swapped for sure.
So that's all a long way of saying I doubt that the batwing bushings are all that critical. But all of this is just an educated guess.
Agreed on all points. I'm picturing this: if the batwing bushings have 1/4" compliance off center in both directions, then as I transition left to right doing a slalom, the whole rear suspension is "sloshing" 1/2" total back and forth under the chassis. Not as big a deal as uncontrolled camber change, but still unwanted.
the stock batwing bushings move around more than you would think . I was hesitant on changing them mid season as a Championship was on the line . After counting threads on the spring bolts , changed the bushings , put it all back together I gained 3/8 in ride height . the bushings sagged that much . Tires rubbing the inner fender wells brought this to my attention .I run 315s /Rcomp tires and they rubbed in high
G loaded corners .Im still sorting this out , I have only run the new set up once and it was in the rain . ( I was second fastest time of the day btw )
