700r4 transmission help needed
Old Dec 3, 2016 | 02:28 PM
Fatdesoto's Avatar
Fatdesoto
6th Gear
Default 700r4 transmission help needed
I was changing the oil on my 86 Vette today and searching for an apparent trans fluid leak. As I inspected I noticed 2 small wiring harnesses running down the drivers side of the trans. One looked like it went to a speed sensor and the other was midway to a socket. Both had the insulation burned off. Does anyone know what they are, where I can get new ones and the likely cause of the burnt wires?
Old Dec 3, 2016 | 02:35 PM
Tom454's Avatar
Tom454
I just burned up a bunch of wires with an over-rich fuel burn... the cat & pipe got red hot and melted it all.
Old Dec 3, 2016 | 03:26 PM
BOOT77's Avatar
BOOT77
Post a pic of the damage for better suggestions, if it's not bad why not just splice in some new wire & zip-tie it up farther? Socket one I'm assuming is the converter lock up connector. My wires are tucked up nice on my 86.
To 700r4 transmission help needed
