LPE219specs
Old Sep 19, 2002 | 10:56 AM
Caboboy's Avatar
Caboboy
Default LPE219specs
Does anybody have the valve event info on an LPE219? I'd like to play with it on desktop dyno. TIA :cheers:
Old Sep 19, 2002 | 11:00 AM
scorp508's Avatar
scorp508
For what its worth I don't trust DD2K worth a damn for its output #s. What I do look at are the changes in the power curve when you make modifications.
Here ya go...
http://personal.tmlp.com/scorp/vette...lter_74219.cam
Old Sep 19, 2002 | 11:24 AM
Caboboy's Avatar
Caboboy
Default Re: (scorp508)
Damn that was quick. You've got everything at your fingertips it seems. Help me decipher this please, 31 & 67 degrees are the event tables, but the .56 is the lift? With 1.6 rockers? Also, I can't find the LSA on his site, any idea on that? Thanx a lot :cheers:
BTW, agreed on both points. The curve is the most important indicator anyway. If I believed the gross numbers DD indicated on the mockups, I could launch to the moon :lol:
Old Sep 19, 2002 | 11:26 AM
scorp508's Avatar
scorp508
The LSA is 112. That file "should" have everything you need already in it. Yes, .560 is the lift with 1.6 rockers. the cam is...
219/219 duration
.525/.525 lift w/1.5
.560/.560 lift w/1.6
112 lsa
To LPE219specs
