Header gasket or aluminum paste
Old Dec 15, 2016 | 03:46 PM
Lt4-396's Avatar
Lt4-396
Default Header gasket or aluminum paste
I'm going to be putting the stainless works headers on a friends lt4, I normally would use remflex aluminum gasket but the headers came with this "aluminized" paste that is in a normal silicone squeeze tube supplied by SW.
Should I use the gasket maker, a normal (remflex) gasket or put a tiny coating of the paste on each mating surface WITH a gasket?
Thanks,
Old Dec 15, 2016 | 04:18 PM
ddahlgren's Avatar
ddahlgren
The beauty of a gasket is that it both compresses and also fills in voids something I suspect a paste is hard pressed to do as is aluminum..
Old Dec 15, 2016 | 04:59 PM
cv67's Avatar
cv67
St. Jude Donor '05
just use a gasket
Is the tube antisieze by chance for the bolts?
Old Dec 15, 2016 | 07:07 PM
383vett's Avatar
383vett
just use a gasket
Good question. I would just call Stainless Works. It's their header and they are a reputable company.
To Header gasket or aluminum paste
