Horn not working?
Old Sep 19, 2002 | 07:14 PM
Damien89's Avatar
Damien89
Default Horn not working?
My horn is not working on my 89 vette i dont know why but it used to work a couple of days ago, i tried the alarm to see if there any wires cut but everything worked fine. I think its something in the sterring column, the car was stored for a long time maybe it got jammed? :chevy :confused:
Old Sep 19, 2002 | 07:36 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Horn not working? (Damien89)
Pop the horn button and clean the contacts; bend them if necessary.
Old Sep 19, 2002 | 08:02 PM
Damien89's Avatar
Damien89
Default Re: Horn not working? (65Z01)
how do you pop the horn button??
Old Sep 19, 2002 | 08:26 PM
65Z01's Avatar
65Z01
I just put a flat blade under the edge and pried up. Just use a little caution not to mar the leather.
Old Sep 20, 2002 | 08:41 AM
Damien89's Avatar
Damien89
thanks mate
Old Sep 20, 2002 | 03:15 PM
JonM's Avatar
JonM
In the picture...the piece on the right, usually breaks off the piece on the left...
Old Sep 20, 2002 | 05:43 PM
85vetteguy's Avatar
85vetteguy
Yea, if your alarm is working it is more than likely a bad contact or loose wire in the steering column. As said before, take it all apart and clean, look for loose wires or broken contacts. Good Luck, guy
To Horn not working?
