Coolant through the TB?
Old Dec 21, 2016 | 11:16 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Requirements are high humidity, low temps, part throttle operation. As the air passes through the partially opened throttle plates, pressure drops, air cools and can/will cool the TB housing and blades. Incoming moisture freezes to those cold metal objects, then builds...and you have "TB Icing". It CAN happen, but I've never seen it in my 30 years of driving carb'ed, TBI and MPFI cars -all with their intake heating systems removed.
One time I was driving over Monarch Pass in Colorado (11,300' elevation). It was at night, in a blizzard, I was driving my carb'ed Trans Am, with of course, the heat stove removed, theh cowl valve propped open all the time, and the exhaust crossover blocked. More hp, right?
Toward the summit, the car started to die out and have power issues. I was barely able to coax it over the summit and then I was fine all the way back down and on to Telluride. I was absolutely convinced; cold temps, high humidity (dumping snow), part throttle, not heating aids...I'd just experienced carb icing.
In reality, it was a clogged fuel filter and I was actually experiencing not carb icing, but "fuel starvation".
Old Dec 22, 2016 | 11:29 AM
Lazy Tom's Avatar
Lazy Tom
Default Trade Off
All design is a compromise.
Intake systems on engines can ice. Carburetors on airplanes have a carb heat **** for that reason. I've had a carb freeze on a Jeep once and a motorcycle (Just let it sit there and thaw from the engine heat. I had to push the motor.)
The heated TB is for reliability reasons.
Intake systems are kept cool to maximize the intake charge so taking it off would be conducive to making more power.
Old Dec 22, 2016 | 05:40 PM
bill mcdonald's Avatar
bill mcdonald
Originally Posted by BacknBlack
Bypassing also yields a little more hp. More than you would think:
http://www.ws6.com/mod-8.htm
Interesting. I would not think as much myself. Now this brings to question what would you gain if you could freeze the water in the bypass only? Seems like such a brief moment of air contact would be nothing as far as gains.
The one question I have is, is this WS6 an LSX engine?
As for why, I have seen this on many makes as well, it is just common tech to keep a TB from freezing shut if possible. I don't live where it is a problem, minus a few odd days of the year. I bypassed it on my l98 and LS6. I noticed nothing. Might try it on the Toyota, even though the other night the back window was caked with ice. I had to find the defroster button.
Old Dec 22, 2016 | 05:46 PM
aklim's Avatar
aklim
I have seen some people put a bag of ice on the manifold while at the track and pushing the car to the line. They pull it off, start the car and run.
Why would you notice anything? Your SOTP dyno doesn't measure small changes and why would you rely on it to tell anything unless the change does something huge?
Old Dec 22, 2016 | 10:05 PM
llesg's Avatar
llesg
Originally Posted by Silver85
Why are there coolant lines running through my throttle body? Can't say I have ever seen this arrangement on another vehicle.
I noticed after 94 it is eliminated.
So I bought water hoses for a 95 and eliminated it also
Old Dec 23, 2016 | 02:40 AM
BacknBlack's Avatar
BacknBlack
That ws6 is a '97, so it's a LT1. I bypassed the TB in my vette and I noticed better throttle response after hot starts. It also kept IAT temps down a bit.
