Horn Relay location
Old Dec 21, 2016 | 02:46 PM
BIG EASY BOB's Avatar
BIG EASY BOB
Default Horn Relay location
Trying to find the horn relay on my 94...No shop or owners manual, Thanks in advance for any help.
Old Dec 21, 2016 | 03:29 PM
antfarmer2's Avatar
antfarmer2
I believe it is on the pass side under the dash. But if your horns are not working I would jump the horns with 12 volts first. If they work the check your horn buttons in the air bag. That is what mine did on my 94 they crumble 60 bucks off ebay and 10 minutes. Pull power first do not want to get bagged.
Old Dec 21, 2016 | 03:30 PM
WVZR-1's Avatar
WVZR-1
Under the right side of the IP. Remove the RH hush panel/foot-well lamp panel and there'll be a relay center.
Name:  '94 under IP RH.png
This will get you an "OWNERS MANUAL" for free.
https://my.chevrolet.com/content/dam...tte_owners.pdf
If the link fails this one will get you started. You do NOT need to establish an account to get access to the owners manuals.
https://my.chevrolet.com/learn
Old Dec 21, 2016 | 04:53 PM
BIG EASY BOB
Thank You, Thats the info I needed.
To Horn Relay location
