Mods for an 85?
Old Sep 20, 2002 | 01:56 AM
LEERJ1's Avatar
LEERJ1
Default Mods for an 85?
I just got my car and need to get some mods done to it. I have noticed that the box has been cut around the filter but that is all so far that I have seen. Please post any that you know of for this year and any that can help get me my power that I crave. Thanks ahead of time and have a great one. Ooh-Rah!!!!!!!!!!! :flag :seeya
Old Sep 20, 2002 | 10:09 AM
vettmech's Avatar
vettmech
Default Re: Mods for an 85? (LEERJ1)
WELL........ where do you want to start? maybe by investigating what else they may have done first. Did they put in a K&N filter? How about an airfoil in the throttle body?........... has the MAF been modified or replaced with a modded unit?. What about the exhaust? .........maybe a cat back system is there......... what I'm trying to point out is investigate what you have and then decide where you want to take it :seeya
Old Sep 20, 2002 | 10:26 AM
LD85's Avatar
LD85
In the middle of building up my 85. So how much power or better to ask how much money will you want to spend?
Old Sep 20, 2002 | 10:43 AM
Corvette0096's Avatar
Corvette0096
Headers. I have been reading gains of 25+ hp.
Old Sep 20, 2002 | 12:02 PM
vettmech's Avatar
vettmech
Default Re: Mods for an 85? (corvette0096)
An old timer once told me :" speed costs money........how fast do you want to go?" :seeya
Old Sep 20, 2002 | 01:33 PM
vader86's Avatar
vader86
It all depends on how fast you want to go basically. But i think the best advice is to drive the car for about 6mos. and fix anything that breaks and also get a good feel of what you want from the car.
However, the free stuff and the mods are usually:
1. Remove the two screens on the front and back of the MAF sensor (which is between the accordian hose and the air filter box).
2. 160 thermostat
3. K&N filter, although i bet you have it already if the lid is cut open.
4. Throttle body bypass (disconnect the hoses leading into the TB and mate them together)
5. fan switch, wire it to the main fan so the coolant temps will stay reasonable.
For the bigger stuff, you should start with a hp #, or an ET in the 1/4mi you want to shoot for.
Headers Longtubes, ceramic coated~15hp
Good exhaust~10hp, add a Random Tech Cat for best flow
AFR 190 heads~hp varies greatly, depends on intake and cam
Then decide which of the 3 routes to big hp: Superram, Miniram, modded out TPI (bigger base, runners, ported plenum). These 3 setups will dictate what cam you pick as well.
Old Sep 20, 2002 | 05:38 PM
mshay's Avatar
mshay
Default Re: Mods for an 85? (vader86)
Don't forget about displacment. More is certainly better!
Old Sep 23, 2002 | 10:01 AM
LEERJ1's Avatar
LEERJ1
thanks everyone. i appreciate all of your help. i dont really want the spped all of thime but when i want it there for back up i need it then. i would like to to add maybe about another 175-225 in hp and torque. i know it is expensive but have no problems with the money. I dont want to add nos though. Thanks again guys. Leerj1 says have a good day. :seeya :flag
Old Sep 23, 2002 | 12:38 PM
vader86's Avatar
vader86
You will need more cubes, SR/MR
Old Sep 23, 2002 | 08:42 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
then you need something like this :cheers:
Old Sep 23, 2002 | 09:15 PM
GRX's Avatar
GRX
Get serious and go here: http://www.carrollsupercharging.com/ :yesnod:
Old Sep 23, 2002 | 09:30 PM
cayboy's Avatar
cayboy
Learn to drive the car as is :yesnod:
Contact forum member Marcho Polo for one of his chips!
Do the cheapest mods first.
Save up your $$$ for later mods :eek:
Have fun!
Steve
To Mods for an 85?
